A reconstruction method for the inverse gravimetric problem
We propose a reconstruction method to solve the inverse gravimetric problem with constant mass density. The method is based on the computation of the harmonic moments of the unknown domain. Convergence results are proved and numerical experiments are provided to illustrate the method and show its efficiency.
A_reconstruction_method_for_the_inverse_gravimetric_problem_unformated.pdf (5.94 Mo)
Télécharger le fichier
