Uncertainty reduction in robust optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Uncertainty reduction has recently been introduced in the robust optimization literature as a relevant special case of decisiondependent uncertainty. Herein, we first show that when the uncertainty reduction decisions are constrained, the resulting optimization problem is NP-hard. We further show that relaxing these constraints leads to solving a linear number of deterministic problems in certain special cases and illustrate the numerical relevance of this result. We further provide insights into possible MILP reformulations and the strength of their continuous relaxations.
uncertainty_red.pdf (177.23 Ko) Télécharger le fichier
hal-04158877 , version 1 (11-07-2023)
hal-04158877 , version 2 (31-01-2024)
  • HAL Id : hal-04158877 , version 2
Ayşe Nur Arslan, Michael Poss. Uncertainty reduction in robust optimization. 2023. ⟨hal-04158877v2⟩
150 Consultations
78 Téléchargements
