Construction of minimizing travelling waves for the Gross-Pitaevskii equation on $\mathbb{R} \times \mathbb{T}$ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Tunisian Journal of Mathematics Année : 2024
Philippe Gravejat
  • Fonction : Auteur
  • PersonId : 1269711
Didier Smets
As a sequel to our previous analysis in [9] on the Gross-Pitaevskii equation on the product space $\mathbb{R} \times \mathbb{T}$, we construct a branch of finite energy travelling waves as minimizers of the Ginzburg-Landau energy at fixed momentum. We deduce that minimizers are precisely the planar dark solitons when the length of the transverse direction is less than a critical value, and that they are genuinely two-dimensional solutions otherwise. The proof of the existence of minimizers is based on the compactness of minimizing sequences, relying on a new symmetrization argument that is well-suited to the periodic setting.
dLGS2-Product-GP-Final.pdf (570.78 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-04160067 , version 1 (12-07-2023)
  • HAL Id : hal-04160067 , version 1
André de Laire, Philippe Gravejat, Didier Smets. Construction of minimizing travelling waves for the Gross-Pitaevskii equation on $\mathbb{R} \times \mathbb{T}$. Tunisian Journal of Mathematics, In press. ⟨hal-04160067⟩
28 Consultations
13 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
