Construction and analysis of a HDG+ method for the diffusive-flux formulation of the convected Helmholtz equation
We construct HDG methods based on the diffusive flux formulation of the convected acoustic wave equation.We mostly describe the HDG+ method which involves different polynomial degrees for approximating the unknowns, hence leading to a more efficient method with a super-convergencelike behaviour. A detailed analysis of the methods including local and global well-posedness, as well as convergence estimates is carried out. The HDG+ method is also compared with a more conventional HDG method to demonstrate its effectiveness.
