Definitional Functoriality for Dependent (Sub)Types - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Dependently-typed proof assistant rely crucially on a definitional equality, identifying the types and terms that are automatically undistinguishable for the underlying type theory. This paper extends type theory with definitional functor laws, two equations satisfied propositionally by a large class of container-like type con- structors F: Type → Type, equipped with a mapF : (A → B) → F A → F B, such as lists or trees. Promot- ing these equations to definitional ones strengthen the theory, enabling slicker proofs and more automation for functorial type constructors. This extension is then used to justify modularly a structural form of coercive subtyping, propagating subtyping through type formers. We show that the resulting notion of coercive sub- typing, thanks to the extra definitional equations, is equivalent to a natural and implicit form of subsumptive subtyping. The key result of decidability of type-checking in a dependent type system with functor laws for lists has been entirely mechanized in Coq
main.pdf (367.98 Ko) Télécharger le fichier
hal-04160858 , version 1 (20-07-2023)
hal-04160858 , version 2 (23-10-2023)
hal-04160858 , version 3 (08-04-2024)
Paternité
  • HAL Id : hal-04160858 , version 1
Théo Laurent, Meven Lennon-Bertrand, Kenji Maillard. Definitional Functoriality for Dependent (Sub)Types. 2023. ⟨hal-04160858v1⟩
194 Consultations
170 Téléchargements
