Temporal Pattern Recognition in Retinal Ganglion Cells is mediated by Dynamical Inhibitory Synapses - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2023
A fundamental task for the brain is to generate predictions of future sensory inputs, and signal errors when these predictions are not matched. To this end, a long-standing hypothesis is that retinal ganglion cells (RGCs), the retinal output, do not signal the visual scene per se, but only surprising events [1].
Neurobiologie
poster_cosyne-2.pdf (1.57 Mo) Télécharger le fichier
hal-04160883 , version 1 (12-07-2023)
  • HAL Id : hal-04160883 , version 1
Simone Ebert, Thomas Buffet, B Semihchan Sermet, Olivier Marre, Bruno Cessac. Temporal Pattern Recognition in Retinal Ganglion Cells is mediated by Dynamical Inhibitory Synapses. COSYNE 2023 - Computational and Systems Neuroscience, Mar 2023, Montreal, Canada. ⟨hal-04160883⟩
25 Consultations
7 Téléchargements
