Notes on overt choice - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computability Année : 2023
Overt choice was recently introduced and thoroughly studied by de Brecht, Pauly and Schröder. They give estimates on the Weihrauch degree of overt choice on various spaces, and relate it to the topological properties of the space. In this article, we pursue this line of research, answering some of the questions that were left open. We show that overt choice on the rationals is not limit-computable. We identify the Weihrauch degree of overt choice on the space of natural numbers with the co-finite topology. We prove that the quasi-Polish spaces are the countably-based T0-spaces on which a variant of overt choice, called Π 0 2 overt choice, is continuous. It extends a previous result that holds in the class of T1-spaces. We also prove an effective version of this equivalence.
article (1).pdf (385.41 Ko) Télécharger le fichier
article.pdf (388.71 Ko) Télécharger le fichier
hal-04164138 , version 1 (18-07-2023)
hal-04164138 , version 2 (06-09-2023)
Paternité
Mathieu Hoyrup. Notes on overt choice. Computability, 2023, pp.1-19. ⟨10.3233/COM-230458⟩. ⟨hal-04164138v2⟩
28 Consultations
20 Téléchargements
