Discrete-Time Trajectory-Based Stabilization Approach using Interval Observer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Control Systems Letters Année : 2023
We provide a discrete-time vector valued analog of recently developed continuous-time trajectory-based estimates. We use it to provide a discrete-time version of Halanay's inequality. We combine the results with interval observers to prove exponential stability properties for discrete-time linear systems with uncertainties whose arbitrarily long input delays are compensated for by reduction model controls, and a robust global exponential stability result for observers for discrete-time linear systems.
Mots clés
fmhalDiscreteTimeTrajectoryBased copie.pdf (1.3 Mo) Télécharger le fichier
hal-04169026 , version 1 (23-07-2023)
hal-04169026 , version 2 (09-08-2023)
Paternité
  • HAL Id : hal-04169026 , version 1
Frederic Mazenc, Michael Malisoff, Jackson Knox. Discrete-Time Trajectory-Based Stabilization Approach using Interval Observer. IEEE Control Systems Letters, 2023. ⟨hal-04169026v1⟩
45 Consultations
24 Téléchargements
