An extended transcription factor regulatory network controls hepatocyte identity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue EMBO Reports Année : 2023
Cell identity is specified by a core transcriptional regulatory circuitry (CoRC), typically limited to a small set of interconnected cell-specific transcription factors (TFs). By mining global hepatic TF regulons, we reveal a more complex organization of the transcriptional regulatory network controlling hepatocyte identity. We show that tight functional interconnections controlling hepatocyte identity extend to non-cell-specific TFs beyond the CoRC, which we call hepatocyte identity (Hep-ID) CONNECT TFs. Besides controlling identity effector genes, Hep-ID CONNECT TFs also engage in reciprocal transcriptional regulation with TFs of the CoRC. In homeostatic basal conditions, this translates into Hep-ID CONNECT TFs being involved in fine tuning CoRC TF expression including their rhythmic expression patterns. Moreover, a role for Hep-ID CONNECT TFs in the control of hepatocyte identity is revealed in dedifferentiated hepatocytes where Hep-ID CONNECT TFs are able to reset CoRC TF expression. This is observed upon activation of NR1H3 or THRB in hepatocarcinoma or in hepatocytes subjected to inflammationinduced loss of identity. Our study establishes that hepatocyte identity is controlled by an extended array of TFs beyond the CoRC.
embr.202357020.pdf (37.25 Mo) Télécharger le fichier
Origine : Publication financée par une institution
Licence : CC BY - Paternité
hal-04169341 , version 1 (24-07-2023)
Paternité
Julie Dubois‐chevalier, Céline Gheeraert, Alexandre Berthier, Clémence Boulet, Vanessa Dubois, et al.. An extended transcription factor regulatory network controls hepatocyte identity. EMBO Reports, 2023, 24 (9), ⟨10.15252/embr.202357020⟩. ⟨hal-04169341⟩
46 Consultations
10 Téléchargements
