Wasserstein contraction for the stochastic Morris-Lecar neuron model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Neuron models have attracted a lot of attention recently, both in mathematics and neuroscience. We are interested in studying long-time and largepopulation emerging properties in a simplified toy model. From a mathematical perspective, this amounts to study the long-time behaviour of a degenerate reflected diffusion process. Using coupling arguments, the flow is proven to be a contraction of the Wasserstein distance for long times, which implies the exponential relaxation toward a (non-explicit) unique globally attractive equilibrium distribution. The result is extended to a McKean-Vlasov type non-linear variation of the model, when the mean-field interaction is sufficiently small. The ergodicity of the process results from a combination of deterministic contraction properties and local diffusion, the noise being sufficient to drive the system away from non-contractive domains.
paper.pdf (371.48 Ko) Télécharger le fichier
hal-04170316 , version 1 (25-07-2023)
hal-04170316 , version 2 (30-01-2024)
  • HAL Id : hal-04170316 , version 2
Maxime Herda, Pierre Monmarché, Benoît Perthame. Wasserstein contraction for the stochastic Morris-Lecar neuron model. 2024. ⟨hal-04170316v2⟩
55 Consultations
18 Téléchargements
