INFINITY: Neural Field Modeling for Reynolds-Averaged Navier-Stokes Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
For numerical design, the development of efficient and accurate surrogate models is paramount. They allow us to approximate complex physical phenomena, thereby reducing the computational burden of direct numerical simulations. We propose INFINITY, a deep learning model that utilizes implicit neural representations (INRs) to address this challenge. Our framework encodes geometric information and physical fields into compact representations and learns a mapping between them to infer the physical fields. We use an airfoil design optimization problem as an example task and we evaluate our approach on the challenging AirfRANS dataset, which closely resembles real-world industrial use-cases. The experimental results demonstrate that our framework achieves state-of-the-art performance by accurately inferring physical fields throughout the volume and surface. Additionally we demonstrate its applicability in contexts such as design exploration and shape optimization: our model can correctly predict drag and lift coefficients while adhering to the equations.
2307.13538.pdf (2.51 Mo) Télécharger le fichier
hal-04171439 , version 1 (26-07-2023)
Paternité
Louis Serrano, Leon Migus, Yuan Yin, Jocelyn Ahmed Mazari, Patrick Gallinari. INFINITY: Neural Field Modeling for Reynolds-Averaged Navier-Stokes Equations. Workshop on Synergy of Scientific and Machine Learning Modeling (ICML 2023), Jul 2023, Honolulu, HI, United States. ⟨hal-04171439⟩
50 Consultations
57 Téléchargements
