Delay-Difference Approximations of PD-Controllers. Improperly-posed Systems in Multiple Delays Case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2024
In this paper, we study the behavior of characteristic roots of a class of strictly proper LTI SISO systems that are subject to a PD controller for which the derivative action has been implemented by means of a delay-difference approximation scheme that uses multiple delays. To such an end, the improperly-posed case is discussed in depth, i.e. the situations where small delays induce instability in the closed-loop system. The effect of adding more delays on the improperly-posed case is analyzed and an algorithm for determining the set of parameters that produces such a situation for a given number of delays is derived. Some illustrative examples complete the presentation.
Fichier sous embargo
0 11 18
Année Mois Jours
Avant la publication
vendredi 16 mai 2025
Connectez-vous pour demander l'accès au fichier
hal-04172009 , version 1 (15-01-2024)
César‐fernando Méndez-Barrios, Juan‐diego Torres-García, Silviu‐iulian Niculescu. Delay-Difference Approximations of PD-Controllers. Improperly-posed Systems in Multiple Delays Case. International Journal of Robust and Nonlinear Control, 2024, ⟨10.1002/rnc.7217⟩. ⟨hal-04172009⟩
115 Consultations
28 Téléchargements
