Uniform boundary stabilization of a high-order finite element space discretization of the 1-d wave equation
The objective of this work is to propose and analyze numerical schemes for solving boundary control problems or data assimilation problems by observers for wave propagation problems. The efficiency of the considered control or data assimilation strategy relies on the exponentially stable character of the underlying system. Therefore, the aim of our work is to propose a discretization process that allows preserving the exponential stability at the discrete level when using high-order spectral finite element approximation. The main idea is to add a stabilizing term to the wave equation that dampens the spurious oscillatory components of the solutions. This term is based on a discrete multiplier analysis that gives us the exponential stability of the semi-discrete problem at any order without affecting the approximation properties.
Licence : CC BY - Paternité
