"Prediction of sleepiness ratings from voice by man and machine" : the Endymion replication perceptual study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Following the release of the SLEEP corpus during the Interspeech 2019 paralinguistic continuous sleepiness estimation challenge, a paper presented at Interspeech 2020 by Huckvale et al. examined the reasons for the poor performance of the models proposed for this task. They conducted a perceptual experiment on a subset of this corpus that seems to indicate that human hearing is, however, able to estimate sleepiness in this corpus. In this study, we present the results of the Endymion replication study, in which the same samples were rated by thirty French-speaking naive listeners. We then discuss the causes of the differences between the two studies and examine the effect of listener and sample characteristics on annotation performances.
Linguistique
icphs_SLEEP_publiee.pdf (6.56 Mo) Télécharger le fichier
hal-04180701 , version 1 (16-08-2023)
  • HAL Id : hal-04180701 , version 1
Vincent P. Martin, Jean-Luc Rouas, Aymeric Ferron, Pierre Philip. "Prediction of sleepiness ratings from voice by man and machine" : the Endymion replication perceptual study. ICPhS 2023 - 20th International Congress of Phonetic Sciences, Aug 2023, Prague, Czech Republic. pp.201-205. ⟨hal-04180701⟩
Collections
CNRS INRIA INRIA2
10 Consultations
4 Téléchargements
