A Centrality Approach to Select Offloading Data Aggregation Points in Vehicular Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Intelligent Transportation Systems Année : 2023
This work proposes a centrality-based approach to identify data offloading points in a VSN. The solution presents a scheme to select vehicles used as aggregation points to collect and aggregate other vehicles’ data before uploading it to processing stations. We evaluate the proposed solution in a realistic simulation scenario derived from data traffic containing more than 700,000 individual car trips for 24 hours. We compare our approach with both a reservation-based algorithm and the optimal solution. Our results indicate an upload cost reduction of 30.92% using the centrality-based algorithm and improving the aggregation rate by up to 10.45% when considering the centralized scenario.
T_ITS___A_Centrality_Approach_to_Select_Offloading_Data_Aggregation_Points_in_Vehicular_Sensor_Networks_.pdf (1.54 Mo) Télécharger le fichier
hal-04189908 , version 1 (03-11-2023)
Copyright (Tous droits réservés)
Douglas Moura, Geymerson Ramos, Andre Aquino, Antonio Loureiro. A Centrality Approach to Select Offloading Data Aggregation Points in Vehicular Sensor Networks. IEEE Transactions on Intelligent Transportation Systems, 2023, 24 (11), pp.11639 - 11653. ⟨10.1109/TITS.2023.3297886⟩. ⟨hal-04189908⟩
100 Consultations
16 Téléchargements
