Hyperbolicity of a semi-Lagrangian formulation of the hydrostatic free-surface Euler system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
By a semi-Lagrangian change of coordinates, the hydrostatic Euler equations describing free-surface sheared flows is rewritten as a system of quasilinear equations, where stability conditions can be determined by the analysis of its hyperbolic structure. This new system can be written as a quasi linear system in time and horizontal variables and involves no more vertical derivatives. However, the coefficients in front of the horizontal derivatives include an integral operator acting on the new vertical variable. The spectrum of these operators is studied in detail, in particular it includes a continuous part. Riemann invariants are then determined as conserved quantities along the characteristic curves. Examples of solutions are provided, in particular stationary solutions and solutions blowing-up in finite time. Eventually, we propose an exact multi-layer $\mathbb{P}_0$-discretization, which could be used to solve numerically this semi-Lagrangian system, and analyze the eigenvalues of the corresponding discretized operator to investigate the hyperbolic nature of the approximated system.
hal-04190892 , version 1 (30-08-2023)
Bernard Di Martino, Chourouk El Hassanieh, Edwige Godlewski, Julien Guillod, Jacques Sainte-Marie. Hyperbolicity of a semi-Lagrangian formulation of the hydrostatic free-surface Euler system. 2023. ⟨hal-04190892⟩
59 Consultations
0 Téléchargements
