COLLAB-VP: Structure-enhanced VP Detector - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce in this paper a novel structure-enhanced VP detector, CollabVP, which uses a multi-task learning framework to estimate multiple horizontal vanishing points (VPs) from a single RGB image. CollabVP exploits contextual information and scene structures through masks of vertical structures to accurately estimate the horizon line and VP positions. The proposed approach is not limited to Manhattan worlds and can detect any number of VPs.
ICIP_2023_final.pdf (395.3 Ko) Télécharger le fichier
Licence : Copyright (Tous droits réservés)
hal-04192288 , version 1 (31-08-2023)
Abdelkarim Elassam, Gilles Simon, Marie-Odile Berger. COLLAB-VP: Structure-enhanced VP Detector. IEEE International Conference on Image Processing (ICIP 2023), IEEE, Oct 2023, kuala Lumpur, Malaysia. ⟨10.1109/ICIPC59416.2023.10328343⟩. ⟨hal-04192288⟩
50 Consultations
58 Téléchargements
