One-Bend Drawing of $K_n$ in 3D, revisited - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2023
We present a drawing of $K_n$ in three dimensions in which vertices are placed at integer grid points and edges are drawn crossing-free with at most one bend per edge; the bend points are also placed at integer grid points. The drawing is determined by an incremental algorithm and the observed behavior of the algorithm produces an output of volume close to quadratic.
abstract.pdf (639.77 Ko) Télécharger le fichier
Format : Figure, Image
hal-04195317 , version 1 (04-09-2023)
Copyright (Tous droits réservés)
  • HAL Id : hal-04195317 , version 1
Olivier Devillers, Sylvain Lazard. One-Bend Drawing of $K_n$ in 3D, revisited. Michael A. Bekos; Markus Chimani. The 31st International Symposium on Graph Drawing and Network Visualization, Sep 2023, Palermo, Italy. Springer, 2023. ⟨hal-04195317⟩
34 Consultations
21 Téléchargements
