Remote State Estimation of Steered Systems with Limited Communications: an Event-Triggered Approach
In this paper, an approach is proposed for the remote observation of a dynamical system through a data-rate constrained communication channel. The focus is put on discrete-time systems with a Lipschitz nonlinearity, driven by an external signal, and subject to bounded state perturbation and measurement error. The problem at hand is providing estimates of system's state at a remote location, which is connected via a channel, which can only sent limited numbers of bits per unit of time. A solution, named observation scheme, is proposed in the form of several interacting agents. This solution is designed such that the maximum observation error is upper-bounded by a computable quantity dependent on system constants and selectable parameters. The scheme is designed in an eventtriggered fashion, such that the actual communication rate is sometimes much lower than the theoretically evaluated maximum one, as it is demonstrated through simulations.
Domains
Automatic Control Engineering
