Direct assessment of SDO/HMI helioseismology of active regions on the Sun’s far side using SO/PHI magnetograms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Astronomy and Astrophysics - A&A Année : 2023
D. Yang
K. Albert
T. Appourchaux
J. Blanco Rodríguez
A. Gandorfer
D. Germerott
  • Fonction : Auteur
L. Guerrero
  • Fonction : Auteur
P. Gutierrez-Marques
F. Kahil
M. Kolleck
  • Fonction : Auteur
S. Solanki
J. Woch
I. Pérez-Grande
E. Sanchis Kilders
L. Bellot Rubio
D. Calchetti
M. Carmona
W. Deutsch
  • Fonction : Auteur
A. Feller
  • Fonction : Auteur
G. Fernandez-Rico
A. Fernández-Medina
P. García Parejo
J. Gasent Blesa
B. Grauf
  • Fonction : Auteur
K. Heerlein
  • Fonction : Auteur
A. Korpi-Lagg
R. Meller
  • Fonction : Auteur
A. Moreno Vacas
R. Müller
  • Fonction : Auteur
E. Nakai
  • Fonction : Auteur
W. Schmidt
  • Fonction : Auteur
J. Schou
U. Schühle
J. Sinjan
J. Staub
H. Strecker
I. Torralbo
G. Valori
Context. Earth-side observations of solar p modes can be used to image and monitor magnetic activity on the Sun’s far side. In this work, we use magnetograms of the far side obtained by the Polarimetric and Helioseismic Imager (PHI) on board Solar Orbiter (SO) to directly assess the validity of far-side helioseismic holography for the first time. Aims. We wish to co-locate the positions of active regions in helioseismic images and magnetograms and to calibrate the helioseismic measurements in terms of the magnetic field strength. Methods. We identified three magnetograms displaying a total of six active regions on the far side from 18 November 2020, 3 October 2021, and 3 February 2022. The first two dates are from the SO cruise phase and the third is from the beginning of the nominal operation phase. We computed contemporaneous seismic phase maps for these three dates using helioseismic holography applied to the time series of Dopplergrams from the Helioseismic and Magnetic Imager (HMI) at the Solar Dynamics Observatory (SDO). Results. Among the six active regions seen in SO/PHI magnetograms, five of them are identified on the seismic maps at almost the same positions as on the magnetograms. One region is too weak to be detected above the seismic noise. To calibrate the seismic maps, we fit a linear relationship between the seismic phase shifts and the unsigned line-of-sight magnetic field averaged over the active region areas extracted from the SO/PHI magnetograms. Conclusions. SO/PHI provides the strongest evidence so far that helioseismic imaging is able to provide reliable information on active regions on the far side, including their positions, areas, and the mean unsigned magnetic field.
aa46030-23.pdf (7.19 Mo) Télécharger le fichier
hal-04205490 , version 1 (12-10-2023)
Paternité
D. Yang, L. Gizon, Hélène Barucq, J. Hirzberger, D. Orozco Suárez, et al.. Direct assessment of SDO/HMI helioseismology of active regions on the Sun’s far side using SO/PHI magnetograms. Astronomy and Astrophysics - A&A, 2023, 674, pp.A183. ⟨10.1051/0004-6361/202346030⟩. ⟨hal-04205490⟩
70 Consultations
10 Téléchargements
