Revising Weighted Knowledge Bases Using FH-Conditioning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Conditioning is an important task for updating and revising uncertain information when new information, often considered reliable, is added. This paper deals with the so-called Fagin and Halpern (FH-)conditioning within the framework of possibility theory. We discuss in particular the computation of FH-conditioning when it is applied to weighted knowledge bases. We also compare FH-conditioning with the two forms of standard possibilistic conditioning (min-based conditioning and product-based conditioning).
HAL_ENIGMA.pdf (298.32 Ko) Télécharger le fichier
hal-04209092 , version 1 (16-09-2023)
  • HAL Id : hal-04209092 , version 1
Omar Et-Targuy, Ahlame Begdouri, Salem Benferhat, Carole Delenne. Revising Weighted Knowledge Bases Using FH-Conditioning. ENIGMA 2023 - 1st Workshop on AI-driven heterogeneous data management: Completing, merging, handling inconsistencies and query-answeringis, Sep 2023, Rhodes, Greece. ⟨hal-04209092⟩
44 Consultations
50 Téléchargements
