Towards autonomous robot navigation in human populated environments using an Universal SFM and parametrized MPC - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autonomous mobile robot navigation in a human populated and encumbered environment is recognized as a hard problem to be solved in real-time. Most of the time, robots face the so-called 'Freezing Robot Problem', that occurs when the robot stops because no feasible and safe motion can be found. In order to provide to the robot the capability of proactive navigation, in this work we generalize the classical Social Force Model into a Universal Social Force Model (USFM) that attributes to any object surrounding the robot (humans, robots, obstacles) a social behavior. Nonlinear Model Predictive Control (MPC) can be used to solve the autonomous navigation problem since it can take into account all the possible constraints coming from the interaction model between the robot and the different surrounding objects. However, to be effective, MPC requires a sufficiently large prediction horizon, which generally implies a high computational cost. In order to considerably reduce the computational cost, we propose a new control parametrisation based on Thin Plate Spline Radial Basis Functions that allow us to have a large prediction horizon with fewer parameters. The global control framework is validated in simulation with virtual pedestrians, and in real world environments.
IROS23.pdf (962.65 Ko) Télécharger le fichier
hal-04210032 , version 1 (19-09-2023)
Paternité
  • HAL Id : hal-04210032 , version 1
Enrico Fiasché, Philippe Martinet, Ezio Malis. Towards autonomous robot navigation in human populated environments using an Universal SFM and parametrized MPC. IROS 2023 - IEEE/RSJ International Conference on Intelligent Robots and Systems, Oct 2023, Detroit (MI), United States. ⟨hal-04210032⟩
161 Consultations
89 Téléchargements
