Diffusion-based speech enhancement with a weighted generative-supervised learning loss - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2024
Diffusion-based generative models have recently gained attention in speech enhancement (SE), providing an alternative to conventional supervised methods. These models transform clean speech training samples into Gaussian noise centered at noisy speech, and subsequently learn a parameterized model to reverse this process, conditionally on noisy speech. Unlike supervised methods, generative-based SE approaches usually rely solely on an unsupervised loss, which may result in less efficient incorporation of conditioned noisy speech. To address this issue, we propose augmenting the original diffusion training objective with a mean squared error (MSE) loss, measuring the discrepancy between estimated enhanced speech and ground-truth clean speech at each reverse process iteration. Experimental results demonstrate the effectiveness of our proposed methodology.
AYILO_AVDiffSE_ICASSP24.pdf (225.26 Ko) Télécharger le fichier
hal-04210729 , version 1 (19-09-2023)
hal-04210729 , version 2 (19-01-2024)
Paternité
Jean-Eudes Ayilo, Mostafa Sadeghi, Romain Serizel. Diffusion-based speech enhancement with a weighted generative-supervised learning loss. International Conference on Acoustics Speech and Signal Processing (ICASSP), IEEE, Apr 2024, Seoul (Korea), South Korea. ⟨10.48550/arXiv.2309.10457⟩. ⟨hal-04210729v2⟩
103 Consultations
131 Téléchargements
