To Stick or Not to Stick? Studying the Impact of Offset Recovery Techniques During Mid-Air Interactions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Visualization and Computer Graphics Année : 2023
During mid-air interactions, common approaches (such as the god-object method) typically rely on visually constraining the user's avatar to avoid visual interpenetrations with the virtual environment in the absence of kinesthetic feedback. This paper explores two methods which influence how the position mismatch (positional offset) between users' real and virtual hands is recovered when releasing the contact with virtual objects. The first method (sticky) constrains the user's virtual hand until the mismatch is recovered, while the second method (unsticky) employs an adaptive offset recovery method. In the first study, we explored the effect of positional offset and of motion alteration on users' behavioral adjustments and users' perception. In a second study, we evaluated variations in the sense of embodiment and the preference between the two control laws. Overall, both methods presented similar results in terms of performance and accuracy, yet, positional offsets strongly impacted motion profiles and users' performance. Both methods also resulted in comparable levels of embodiment. Finally, participants usually expressed strong preferences toward one of the two methods, but these choices were individual-specific and did not appear to be correlated solely with characteristics external to the individuals. Taken together, these results highlight the relevance of exploring the customization of motion control algorithms for avatars.
2023-TVCG-Mavromatis.pdf (5.61 Mo) Télécharger le fichier
hal-04214485 , version 1 (22-09-2023)
hal-04214485 , version 2 (19-02-2024)
Paternité
Maé Mavromatis, Ludovic Hoyet, Anatole Lécuyer, Diane Dewez, Ferran Argelaguet. To Stick or Not to Stick? Studying the Impact of Offset Recovery Techniques During Mid-Air Interactions. IEEE Transactions on Visualization and Computer Graphics, In press, pp.1 - 14. ⟨10.1109/tvcg.2023.3295209⟩. ⟨hal-04214485v1⟩
52 Consultations
53 Téléchargements
