A new approach based on quadratic forms to attack the McEliece cryptosystem - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2023
We bring in here a novel algebraic approach for attacking the McEliece cryptosystem. It consists in introducing a subspace of matrices representing quadratic forms. Those are associated with quadratic relationships for the component-wise product in the dual of the code used in the cryptosystem. Depending on the characteristic of the code field, this space of matrices consists only of symmetric matrices or skew-symmetric matrices. This matrix space is shown to contain unusually low-rank matrices (rank $2$ or $3$ depending on the characteristic) which reveal the secret polynomial structure of the code. Finding such matrices can then be used to recover the secret key of the scheme. We devise a dedicated approach in characteristic $2$ consisting in using a Gr\"obner basis modeling that a skew-symmetric matrix is of rank $2$. This allows to analyze the complexity of solving the corresponding algebraic system with Gr\"obner bases techniques. This computation behaves differently when applied to the skew-symmetric matrix space associated with a random code rather than with a Goppa or an alternant code. This gives a distinguisher of the latter code family. We give a bound on its complexity which turns out to interpolate nicely between polynomial and exponential depending on the code parameters. A distinguisher for alternant/Goppa codes was already known [FGO+11]. It is of polynomial complexity but works only in a narrow parameter regime. This new distinguisher is also polynomial for the parameter regime necessary for [FGO+11] but contrarily to the previous one is able to operate for virtually all code parameters relevant to cryptography. Moreover, we use this matrix space to find a polynomial time attack of the McEliece cryptosystem provided that the Goppa code is distinguishable by the method of [FGO+11] and its degree is less than $q-1$, where $q$ is the alphabet size of the code.
Dates and versions
hal-04215135 , version 1 (22-09-2023)
Attribution
Identifiers
Cite
Alain Couvreur, Rocco Mora, Jean-Pierre Tillich. A new approach based on quadratic forms to attack the McEliece cryptosystem. ASIACRYPT 2023, Dec 2023, Guangzhou, China. ⟨hal-04215135⟩
53 View
0 Download
Share
