Optimal Energy Tank Initialization for Minimum Sensitivity to Model Uncertainties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Energy tanks have gained popularity inside the robotics and control communities over the last years, since they represent a formidable tool to enforce passivity (and, thus, input/output stability) of a controlled robot, possibly interacting with uncertain environments. One weak point of passification strategies based on energy tanks concerns, however, their initialization. Indeed, a too large initial energy can cause practical unstable behaviors, while a too low initial energy level can prevent the correct execution of the task. This shortcoming becomes even more relevant in presence of uncertainties in the robot model and/or environment, since it may be hard to predict in advance the correct (safe) amount of initial tank energy for a successful task execution. In this paper we then propose a new strategy for addressing this issue. The recent notion of closed-loop state sensitivity is exploited to derive precise bounds (tubes) on the tank energy behavior by assuming parametric uncertainty in the robot model. These tubes are then exploited in a novel nonlinear optimization problem aiming at finding both the best trajectory and the minimal initial tank energy that allow executing a positioning task for any value of the uncertain parameters in a given range. The approach is finally validated via a statistical analysis in simulation and experiments on real robot hardware.
Andrea___IROS2023___Sensitivity.pdf (3.99 Mo) Télécharger le fichier
hal-04216655 , version 1 (25-09-2023)
Paternité
  • HAL Id : hal-04216655 , version 1
Andrea Pupa, Paolo Robuffo Giordano, Cristian Secchi. Optimal Energy Tank Initialization for Minimum Sensitivity to Model Uncertainties. IROS 2023 - IEEE/RSJ International Conference on Intelligent Robots and Systems, Oct 2023, Detroit, MI, United States. pp.1-8. ⟨hal-04216655⟩
70 Consultations
97 Téléchargements
