F-BIDS: Federated-Blending based Intrusion Detection System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Pervasive and Mobile Computing Année : 2023
The rapid development of network communication along with the drastic increase in the number of smart devices has triggered a surge in network traffic, which can contain private data and in turn affect user privacy. Recently, Federated Learning (FL) has been proposed in Intrusion Detection Systems (IDS) to ensure attack detection, privacy preservation, and cost reduction, which are crucial issues in traditional centralized machine-learning-based IDS. However, FL-based approaches still exhibit vulnerabilities that can be exploited by adversaries to compromise user data. At the same time, meta-models (including the blending models) have been recognized as one of the solutions to improve generalization for attack detection and classification since they enhance generalization and predictive performances by combining multiple base models. Therefore, in this paper, we propose a Federated Blending model-driven IDS framework for the Internet of Things (IoT) and Industrial IoT (IIoT), called F-BIDS, in order to further protect the privacy of existing ML-based IDS. The proposition consists of a Decision Tree (DT) and Random Forest (RF) as base classifiers to first produce the meta-data. Then, the meta-classifier, which is a Neural Networks (NN) model, uses the meta-data during the federated training step, and finally, it makes the final classification on the test set. Specifically, in contrast to the classical FL approaches, the federated meta-classifier is trained on the meta-data (composite data) instead of user-sensitive data to further enhance privacy. To evaluate the performance of F-BIDS, we used the most recent and open cyber-security datasets, called Edge-IIoTset (published in 2022) and InSDN (in 2020). We chose these datasets because they are recent datasets and contain a large amount of network traffic including both malicious and benign traffic.
F_BIDS__hal_copy_.pdf (1.32 Mo) Télécharger le fichier
hal-04223515 , version 1 (04-10-2023)
hal-04223515 , version 2 (06-10-2023)
Paternité
Ons Aouedi, Kandaraj Piamrat. F-BIDS: Federated-Blending based Intrusion Detection System. Pervasive and Mobile Computing, 2023, 89, pp.101750. ⟨10.1016/j.pmcj.2023.101750⟩. ⟨hal-04223515v2⟩
62 Consultations
112 Téléchargements
