A path-norm toolkit for modern networks: consequences, promises and challenges - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
This work introduces the first toolkit around path-norms that is fully able to encompass general DAG ReLU networks with biases, skip connections and any operation based on the extraction of order statistics: max pooling, GroupSort etc. This toolkit notably allows us to establish generalization bounds for modern neural networks that are not only the most widely applicable path-norm based ones, but also recover or beat the sharpest known bounds of this type. These extended path-norms further enjoy the usual benefits of path-norms: ease of computation, invariance under the symmetries of the network, and improved sharpness on feedforward networks compared to the product of operators' norms, another complexity measure most commonly used. The versatility of the toolkit and its ease of implementation allow us to challenge the concrete promises of path-norm-based generalization bounds, by numerically evaluating the sharpest known bounds for ResNets on ImageNet.
HAL_path_norm.pdf (918.32 Ko) Télécharger le fichier
hal-04225201 , version 1 (02-10-2023)
hal-04225201 , version 2 (19-10-2023)
hal-04225201 , version 3 (24-11-2023)
hal-04225201 , version 4 (13-03-2024)
  • HAL Id : hal-04225201 , version 2
Antoine Gonon, Nicolas Brisebarre, Elisa Riccietti, Rémi Gribonval. A path-norm toolkit for modern networks: consequences, promises and challenges. 2023. ⟨hal-04225201v2⟩
109 Consultations
69 Téléchargements
