Physics-Informed Neural Networks for Multiphysics Coupling: Application to Conjugate Heat Transfer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2023
Physics-Informed Neural Networks (PINNs) have emerged as a promising paradigm for modeling complex physical phenomena, offering the potential to handle diverse scenarios to simulate coupled systems. This is a supervised or unsupervised deep learning approach that aims at learning physical laws described by partial differential equations. This report presents an exploration of PINNs through three distinct test cases: heat transfer, and conjugate heat transfer, with forced and natural convection. The investigations reveal PINNs' proficiency in accommodating parameterized resolution, addressing piece-wise constant conditions, and enabling multiphysics coupling. Despite their versatility, challenges emerged, including difficulties in achieving high accuracy, error propagation near singularities, and limitations in scenarios with high Rayleigh values.
RR-9520.pdf (8.94 Mo) Télécharger le fichier
Licence : Domaine public
hal-04225990 , version 1 (05-10-2023)
Domaine public
  • HAL Id : hal-04225990 , version 1
Guillaume Coulaud, Régis Duvigneau. Physics-Informed Neural Networks for Multiphysics Coupling: Application to Conjugate Heat Transfer. RR-9520, Université Côte d'Azur, Inria, CNRS, LJAD. 2023. ⟨hal-04225990⟩
308 Consultations
295 Téléchargements
