Approximate and exact controllability criteria for linear one-dimensional hyperbolic systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
This paper deals with the controllability of linear one-dimensional hyperbolic systems. Reformulating the problem in terms of linear difference equations and making use of infinite-dimensional realization theory, we obtain both necessary and sufficient conditions for approximate and exact controllability, expressed in the frequency domain. The results are applied to flows in networks.
Controllability_hyperbolic_system_preprint.pdf (399.39 Ko) Télécharger le fichier
hal-04228797 , version 1 (04-10-2023)
hal-04228797 , version 2 (05-01-2024)
hal-04228797 , version 3 (06-05-2024)
Paternité
  • HAL Id : hal-04228797 , version 2
Yacine Chitour, Sébastien Fueyo, Guilherme Mazanti, Mario Sigalotti. Approximate and exact controllability criteria for linear one-dimensional hyperbolic systems. 2023. ⟨hal-04228797v2⟩
135 Consultations
95 Téléchargements
