Observer Design via Non-Monotone Lyapunov Functions for Monitoring Heterotrophic Microalgae - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose an observer to estimate the biomass of microalgae growing under heterotrophic conditions. In the heterotrophic microalgae modeling we have assumed that it is growth-limited by multiple substrate, acetate and oxygen. Then, we design a nonlinear observer through a combination of Lyapunov's direct method and exact convex representations, the design conditions are given in terms of linear matrix inequalities (LMIs). The observer is implemented in simulation, and additionally, we compare our proposal with existing conditions.
_IFAC_2023__Observer_Design_via_Non_Monotone_Lyapunov_Functions_for_Monitoring_Heterotrophic_Microalgae-1.pdf (528.47 Ko) Télécharger le fichier
hal-04229860 , version 1 (05-10-2023)
Paternité
  • HAL Id : hal-04229860 , version 1
Juan Carlos Arceo, Olivier Bernard, Jean-Luc Gouzé. Observer Design via Non-Monotone Lyapunov Functions for Monitoring Heterotrophic Microalgae. 22nd IFAC World Congress, 2023, Yokohama, Japan. ⟨hal-04229860⟩
34 Consultations
28 Téléchargements
