Computing and Visualizing Agro-Meteorological Parameters based on an Observational Weather Knowledge Graph
Linked-data principles are more and more adopted to integrate and publish semantically described open data using W3C standards resulting in a large amount of available resources [7]. In particular, meteorological sensor data have been uplifted into public RDF graphs, such as WeKG-MF which offers access to a large set of meteorological variables described through spatial and temporal dimensions. Nevertheless, these resources include huge numbers of raw observations that are tedious to be explored and reused by lay users. In this paper, we leverage WeKG-MF to compute important agro-meteorological parameters and views with SPARQL queries. As a result, we deployed a LOD platform as a web application to allow users to navigate, consume and produce linked datasets of agro-meterological parameters calculated on-the-fly.
Informatique [cs]
Yacoubi et al 2023 Computing and Visualizing Agro-Meteorological Parameters based on an Observational Weather KG.pdf (1.58 Mo)
Télécharger le fichier
