Rapid and robust synchronization via weak synaptic coupling
This paper examines how weak synaptic coupling can achieve rapid synchronization in heterogeneous networks. The assumptions aim at capturing the key mathematical properties that make this possible for biophysical networks. In particular, the combination of nodal excitability and synaptic coupling are shown to be essential to the phenomenon.
Licence : CC BY NC ND - Paternité - Pas d'utilisation commerciale - Pas de modification
