Solution of Mismatched Monotone+Lipschitz Inclusion Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
In this article, we study the convergence of algorithms for solving monotone inclusions in the presence of adjoint mismatch. The adjoint mismatch arises when the adjoint of a linear operator is replaced by an approximation, due to computational or physical issues. This occurs in inverse problems, particularly in computed tomography. In real Hilbert spaces, monotone inclusion problems involving a maximally $ρ$-monotone operator, a cocoercive operator, and a Lipschitzian operator can be solved by the Forward-Backward-Half-Forward, the Forward-Douglas-Rachford-Forward, and the Forward-Half-Reflected-Backward methods. We investigate the case of a mismatched Lipschitzian operator. We propose variants of the three aforementioned methods to cope with the mismatch, and establish conditions under which the weak convergence to a solution is guaranteed for these variants. The proposed algorithms hence enable each iteration to be implemented with a possibly iteration-dependent approximation to the mismatch operator, thus allowing this operator to be modified at each iteration. Finally, we present numerical experiments on a computed tomography example in material science, showing the applicability of our theoretical findings.
2310.06402.pdf (1005.22 Ko) Télécharger le fichier
hal-04237154 , version 1 (11-10-2023)
Paternité
Emilie Chouzenoux, Jean-Christophe Pesquet, Fernando Roldán. Solution of Mismatched Monotone+Lipschitz Inclusion Problems. 2023. ⟨hal-04237154⟩
19 Consultations
15 Téléchargements
