A benchmark study on reactive two-phase flow in porous media: Part I -model description - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computational Geosciences Année : 2024
This paper proposes a benchmark study for reactive multiphase multicomponent flow in porous media. Modeling such problem leads to a highly nonlinear coupled system of partial differential equations, ordinary differential equations and algebraic constraints which requires special numerical treatment. The benchmark consists of five test problems in total (both in 1D and in 2D), with varying degrees of difficulty, designed to verify the algorithms and the codes dedicated to simulating coupled isothermal Hydro-Chemical processes during injection and storage of CO 2 in the subsurface. It is intended to be used as a basis for comparing codes in order to better understand different couplings such as chemical reactions with two-phase flow, phase behavior with equilibrium reactions, dissolution and precipitation.
Description-benchmark.pdf (1.07 Mo) Télécharger le fichier
hal-04237764 , version 1 (11-10-2023)
Paternité
Stephan de Hoop, Denis Voskov, Etienne Ahusborde, Brahim Amaziane, Michel Kern. A benchmark study on reactive two-phase flow in porous media: Part I -model description. Computational Geosciences, 2024, ⟨10.1007/s10596-024-10268-z⟩. ⟨hal-04237764⟩
120 Consultations
118 Téléchargements
