Reduced-bias estimation of the extreme conditional tail expectation for Box-Cox transforms of heavy-tailed distributions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Conditional tail expectation (CTE) is a coherent risk measure defined as the mean of the loss distribution above a high quantile. The existence of the CTE as well as the asymptotic properties of associated estimators however require integrability conditions that may be violated when dealing with heavy-tailed distributions. We introduce Box-Cox transforms of the CTE that have two benefits. First, they alleviate these theoretical issues. Second, they enable to recover a number of risk measures such as conditional tail expectation, expected shortfall, conditional value-at-risk or conditional tail variance. The construction of dedicated estimators is based on the investigation of the asymptotic relationship between Box-Cox transforms of the CTE and quantiles at extreme probability levels, as well as on an extrapolation formula established in the heavy-tailed context. We quantify and estimate the bias induced by the use of these approximations and then introduce reduced-bias estimators whose asymptotic properties are rigorously shown. Their finite-sample properties are assessed on a simulation study and illustrated on real data, highlighting the practical interest of both the bias reduction and the Box-Cox transform.
boxcox-CTE.pdf (769.56 Ko) Télécharger le fichier
hal-04243953 , version 1 (16-10-2023)
hal-04243953 , version 2 (11-04-2024)
Paternité
  • HAL Id : hal-04243953 , version 1
Michaël Allouche, Jonathan El Methni, Stéphane Girard. Reduced-bias estimation of the extreme conditional tail expectation for Box-Cox transforms of heavy-tailed distributions. 2023. ⟨hal-04243953v1⟩
102 Consultations
104 Téléchargements
