Toward Job Recommendation for All - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a job recommendation algorithm designed and validated in the context of the French Public Employment Service. The challenges, owing to the confidential data policy, are related with the extreme sparsity of the interaction matrix and the mandatory scalability of the algorithm, aimed to deliver recommendations to millions of job seekers in quasi real-time, considering hundreds of thousands of job ads. The experimental validation of the approach shows similar or better performances than the state of the art in terms of recall, with a gain in inference time of 2 orders of magnitude. The study includes some fairness analysis of the recommendation algorithm. The gender-related gap is shown to be statistically similar in the true data and in the counter-factual data built from the recommendations.
0655.pdf (232.21 Ko) Télécharger le fichier
hal-04245528 , version 1 (17-10-2023)
Guillaume Bied, Solal Nathan, Elia Perennes, Morgane Hoffmann, Philippe Caillou, et al.. Toward Job Recommendation for All. IJCAI 2023 - The 32nd International Joint Conference on Artificial Intelligence, Aug 2023, Macau, China. pp.5906-5914, ⟨10.24963/ijcai.2023/655⟩. ⟨hal-04245528⟩
192 Consultations
114 Téléchargements
