Taming the Diversity of Computational Notebooks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In many applications of Computational Science and especially Data Science, notebooks are the cornerstone of knowledge and experiment sharing. Their diversity is multiple (problem addressed, input data, algorithm used, overall quality) and is not made explicit at all. As they are heavily reused through a clone-and-own approach, the tailoring process from an existing notebook to a specific problem is cumbersome, error-prone, and particularly uncertain. In this paper, we propose a tooled approach that captures the different dimensions of variability in computational notebooks. It allows one to seek an existing notebook that suits her requirements, or to generate most parts of a new one. CCS CONCEPTS • Software and its engineering → Software product lines; • Computing methodologies → Machine learning.
tamingTheDiversity-SPLC2023.pdf (1.29 Mo) Télécharger le fichier
hal-04247860 , version 1 (18-10-2023)
Yann Brault, Yassine El Amraoui, Mireille Blay-Fornarino, Philippe Collet, Florent Jaillet, et al.. Taming the Diversity of Computational Notebooks. SPLC 2023 - 27th ACM International Systems and Software Product Line Conference, Aug 2023, Tokyo, Japan. pp.27-33, ⟨10.1145/3579027.3608974⟩. ⟨hal-04247860⟩
69 Consultations
43 Téléchargements
