Toward the use of proxies for efficient learning manipulation and locomotion strategies on soft robots. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Robotics and Automation Letters Année : 2023
Soft robots are naturally designed to perform safe interactions with their environment, like locomotion and manipulation. In the literature, there are now many concepts, often bio-inspired, to propose new modes of locomotion or grasping. However, a methodology for implementing motion planning of these tasks, as exists for rigid robots, is still lacking. One of the difficulties comes from the modeling of these robots, which is very different, as it is based on the mechanics of deformable bodies. These models, whose dimension is often very large, make learning and optimization methods very costly. In this paper, we propose a proxy approach, as exists for humanoid robotics. This proxy is a simplified model of the robot that enables frugal learning of a motion strategy. This strategy is then transferred to the complete model to obtain the corresponding actuation inputs. Our methodology is illustrated and analyzed on two classical designs of soft robots doing manipulation and locomotion tasks.
proxy_RAL.pdf (4.03 Mo) Télécharger le fichier
hal-04249925 , version 1 (19-10-2023)
Paternité
Etienne Ménager, Quentin Peyron, Christian Duriez. Toward the use of proxies for efficient learning manipulation and locomotion strategies on soft robots.. IEEE Robotics and Automation Letters, In press, ⟨10.48550/arXiv.2310.17029⟩. ⟨hal-04249925⟩
108 Consultations
123 Téléchargements
