False Discovery Proportion control for aggregated Knockoffs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Controlled variable selection is an important analytical step in various scientific fields, such as brain imaging or genomics. In these high-dimensional data settings, considering too many variables leads to poor models and high costs, hence the need for statistical guarantees on false positives. Knockoffs are a popular statistical tool for conditional variable selection in high dimension. However, they control for the expected proportion of false discoveries (FDR) and not their actual proportion (FDP). We present a new method, KOPI, that controls the proportion of false discoveries for Knockoff-based inference. The proposed method also relies on a new type of aggregation to address the undesirable randomness associated with classical Knockoff inference. We demonstrate FDP control and substantial power gains over existing Knockoff-based methods in various simulation settings and achieve good sensitivity/specificity tradeoffs on brain imaging and genomic data.
2310.10373.pdf (1.55 Mo) Télécharger le fichier
hal-04250621 , version 1 (19-10-2023)
Alexandre Blain, Bertrand Thirion, Olivier Grisel, Pierre Neuvial. False Discovery Proportion control for aggregated Knockoffs. NeurIPS 2023 – 37th Conference on Neural Information Processing Systems, Dec 2023, New Orleans, United States. ⟨10.48550/arXiv.2310.10373⟩. ⟨hal-04250621⟩
70 Consultations
38 Téléchargements
