Open Problems in (Hyper)Graph Decomposition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2023
Jakub Lacki
  • Fonction : Auteur
Darren Strash
  • Fonction : Auteur
Large networks are useful in a wide range of applications. Sometimes problem instances are composed of billions of entities. Decomposing and analyzing these structures helps us gain new insights about our surroundings. Even if the final application concerns a different problem (such as traversal, finding paths, trees, and flows), decomposing large graphs is often an important subproblem for complexity reduction or parallelization. This report is a summary of discussions that happened at Dagstuhl seminar 23331 on "Recent Trends in Graph Decomposition" and presents currently open problems and future directions in the area of (hyper)graph decomposition.
2310.11812.pdf (849.7 Ko) Télécharger le fichier
hal-04251953 , version 1 (20-10-2023)
hal-04251953 , version 2 (14-12-2023)
Paternité
Deepak Ajwani, Rob H. Bisseling, Katrin Casel, Ümit V. Çatalyürek, Cédric Chevalier, et al.. Open Problems in (Hyper)Graph Decomposition. Dagstuhl. 2023. ⟨hal-04251953v1⟩
Collections
LARA
53 Consultations
73 Téléchargements
