$hp$-optimal convergence of the original DG method for linear hyperbolic problems on special simplicial meshes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We prove hp-optimal error estimates for the original DG method when approximating solutions to first-order hyperbolic problems with constant convection fields in the $L^2$ and DG norms. The main theoretical tools used in the analysis are novel $hp$-optimal approximation properties of the special projector introduced in [Cockburn, Dong, Guzman, SINUM, 2008]. We assess the numerical results on some test cases.
main.pdf (1.11 Mo) Télécharger le fichier
hal-04252310 , version 1 (20-10-2023)
hal-04252310 , version 2 (08-11-2023)
Paternité
  • HAL Id : hal-04252310 , version 2
Zhaonan Dong, Lorenzo Mascotto. $hp$-optimal convergence of the original DG method for linear hyperbolic problems on special simplicial meshes. 2023. ⟨hal-04252310v2⟩
43 Consultations
17 Téléchargements
