Generating robust counterfactual explanations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Générer des explications contrefactuelles robustes
Counterfactual explanations have become a mainstay of the XAI field. This particularly intuitive statement allows the user to understand what small but necessary changes would have to be made to a given situation in order to change a model prediction. The quality of a counterfactual depends on several criteria: realism, actionability, validity, robustness, etc. In this paper, we are interested in the notion of robustness of a counterfactual. More precisely, we focus on robustness to counterfactual input changes. This form of robustness is particularly challenging as it involves a trade-off between the robustness of the counterfactual and the proximity with the example to explain. We propose a new framework, CROCO, that generates robust counterfactuals while managing effectively this trade-off, and guarantees the user a minimal robustness. An empirical evaluation on tabular datasets confirms the relevance and effectiveness of our approach.
generating_robust_counterfactuals.pdf (783.39 Ko) Télécharger le fichier
hal-04255500 , version 1 (24-10-2023)
Paternité
  • HAL Id : hal-04255500 , version 1
Victor Guyomard, Françoise Fessant, Thomas Guyet, Tassadit Bouadi, Alexandre Termier. Generating robust counterfactual explanations. ECML/PKDD - European Conference on Machine Learning and Principles and Practice of Knowledge Discovery in Databases, Sep 2023, Turin (Italie), Italy. pp.1-16. ⟨hal-04255500⟩
43 Consultations
35 Téléchargements
