Finding many Collisions via Reusable Quantum Walks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Given a random function f with domain [2^n] and codomain [2^m], with m ≥ n, a collision of f is a pair of distinct inputs with the same image. Collision finding is an ubiquitous problem in cryptanalysis, and it has been well studied using both classical and quantum algorithms. Indeed, the quantum query complexity of the problem is well known to be Θ(2^(m/3)), and matching algorithms are known for any value of m. The situation becomes different when one is looking for multiple collision pairs. Here, for 2^k collisions, a query lower bound of Θ(2^((2k+m)/3)) was shown by Liu and Zhandry (EUROCRYPT 2019). A matching algorithm is known, but only for relatively small values of m, when many collisions exist. In this paper, we improve the algorithms for this problem and, in particular, extend the range of admissible parameters where the lower bound is met. Our new method relies on a chained quantum walk algorithm, which might be of independent interest. It allows to extract multiple solutions of an MNRS-style quantum walk, without having to recompute it entirely: after finding and outputting a solution, the current state is reused as the initial state of another walk. As an application, we improve the quantum sieving algorithms for the shortest vector problem (SVP), with a complexity of 2^(0.2563d+o(d)) instead of the previous 2^(0.2570d+o(d)) .
collision-walk.pdf (558.43 Ko) Télécharger le fichier
Licence : CC BY - Paternité
hal-04261002 , version 1 (26-10-2023)
Paternité
Xavier Bonnetain, André Chailloux, André Schrottenloher, Yixin Shen. Finding many Collisions via Reusable Quantum Walks: Application to Lattice Sieving. EUROCRYPT 2023 - International Conference on the Theory and Applications of Cryptographic Techniques, Apr 2023, Lyon, France. pp.221-251, ⟨10.1007/978-3-031-30589-4_8⟩. ⟨hal-04261002⟩
56 Consultations
40 Téléchargements
