On robust observer design for a class of time-varying continuous-and discrete-time Persidskii systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2023
This paper considers the state estimation problem for a class of non-autonomous nonlinear systems. We propose conditions on the existence and stability of a nonlinear observer based on the invariant manifold approach in both continuousand discrete-time scenarios. The requirements are formulated using Linear Matrix Equalities (LME) and Inequalities (LMI). We present two possible applications of the result, a reducedorder observer (e.g., an observer for unmeasured states) and regression in linear and nonlinear, continuous-and discretetime settings. With nonlinear regression being a sophisticated case, the parameter estimation problem for a particular output equation (when the fusion of linear and nonlinear sensors is weighted) is investigated. Two nonlinear examples demonstrating the efficiency of results are provided.
Automatique
_observer_design.pdf (959.93 Ko) Télécharger le fichier
hal-04283035 , version 1 (13-11-2023)
Paternité
  • HAL Id : hal-04283035 , version 1
Anatolii Khalin, Denis Efimov, Rosane Ushirobira. On robust observer design for a class of time-varying continuous-and discrete-time Persidskii systems. IEEE Transactions on Automatic Control, inPress. ⟨hal-04283035⟩
18 Consultations
41 Téléchargements
