A complex-scaled boundary integral equation for time-harmonic water waves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
This paper presents a novel boundary integral equation (BIE) formulation for the two-dimensional time-harmonic water-waves problem. It utilizes a complex-scaled Laplace's free-space Green's function, resulting in a BIE posed on the infinite boundaries of the domain. The perfectly matched layer (PML) coordinate stretching that is used to render propagating waves exponentially decaying, allows for the effective truncation and discretization of the BIE unbounded domain. We show through a variety of numerical examples that, despite the logarithmic growth of the complex-scaled Laplace's free-space Green's function, the truncation errors are exponentially small with respect to the truncation length. Our formulation uses only simple function evaluations (e.g. complex logarithms and square roots), hence avoiding the need to compute the involved water-wave Green's function. Finally, we show that the proposed approach can also be used to find complex resonances through a \emph{linear} eigenvalue problem since the Green's function is frequency-independent.
2310.04127.pdf (1.16 Mo) Télécharger le fichier
Licence : Domaine public
hal-04286461 , version 1 (15-11-2023)
Anne-Sophie Bonnet-Ben Dhia, Luiz Faria, Carlos Pérez-Arancibia. A complex-scaled boundary integral equation for time-harmonic water waves. 2023. ⟨hal-04286461⟩
30 Consultations
10 Téléchargements
