Simplicial subdivision of simplices of arbitrary dimension in a space of constant non-zero curvature with bounded quality - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
In 1942 Freudenthal showed that a simplex in Euclidean space can be subdivided such that the quality (well-shapedness of the simplex, quantified in terms of e.g. fatness) of the simplices in the subdivision is lower bounded. This answered a question of Brouwer. Recently, Brunck discussed the same problem for simplices in two dimensional spaces of constant curvature and provided a closely related construction. In this note we exhibit the close relation between the two constructions and observe that, using radial projection, Freudenthal's construction and result immediately generalize to simplices in spaces of constant non-zero curvature of arbitrary dimension. This note focuses on displaying classical results that may be unfamiliar to people in the field that do not speak German, rather than building new theory.
Simplicial_subdivision_of_simplices_in_spaces_of_constant_curvature-1.pdf (1.07 Mo) Télécharger le fichier
hal-04297480 , version 1 (21-11-2023)
  • HAL Id : hal-04297480 , version 1
Jean-Daniel Boissonnat, Florestan Brunck, Hana Dal Poz Kouřimská, Arijit Ghosh, Mathijs Wintraecken. Simplicial subdivision of simplices of arbitrary dimension in a space of constant non-zero curvature with bounded quality. 2023. ⟨hal-04297480⟩
32 Consultations
28 Téléchargements
