A Control Leonov Function Guaranteeing Global ISS of Two Coupled Synchronverters
The synchronverter control algorithm is a highly promising option for operating AC power inverters in future low-inertia power systems. Yet, as with conventional synchronous generators, the standard synchronverter algorithm only provides limited robustness guarantees. Therefore, we propose an additional control that confers the closed-loop system with global robustness in the Input-to-State Stability (ISS) sense. In this paper, such a control law is derived for the case of two identical synchronverters interconnected over dynamic power lines by using the Control Leonov Function (CLeF) framework. The control is illustrated by simulations.
Domains
Automatic Control Engineering
