Efficient Model-Based Concave Utility Reinforcement Learning through Greedy Mirror Descent - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Many machine learning tasks can be solved by minimizing a convex function of an occupancy measure over the policies that generate them. These include reinforcement learning, imitation learning, among others. This more general paradigm is called the Concave Utility Reinforcement Learning problem (CURL). Since CURL invalidates classical Bellman equations, it requires new algorithms. We introduce MD-CURL, a new algorithm for CURL in a finite horizon Markov decision process. MD-CURL is inspired by mirror descent and uses a non-standard regularization to achieve convergence guarantees and a simple closed-form solution, eliminating the need for computationally expensive projection steps typically found in mirror descent approaches. We then extend CURL to an online learning scenario and present Greedy MD-CURL, a new method adapting MD-CURL to an online, episode-based setting with partially unknown dynamics. Like MD-CURL, the online version Greedy MD-CURL benefits from low computational complexity, while guaranteeing sub-linear or even logarithmic regret, depending on the level of information available on the underlying dynamics.
rpmzfspfrtqryyrvjgxvzxbdhmhhndbb.pdf (1.12 Mo) Télécharger le fichier
my_paper.pdf (1.03 Mo) Télécharger le fichier
hal-04302000 , version 1 (23-11-2023)
Paternité
Bianca Marin Moreno, Margaux Brégère, Pierre Gaillard, Nadia Oudjane. Efficient Model-Based Concave Utility Reinforcement Learning through Greedy Mirror Descent. 2023. ⟨hal-04302000⟩
69 Consultations
50 Téléchargements
