Adaptive Algorithms for Relaxed Pareto Set Identification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Cyrille Kone
  • Fonction : Auteur
  • PersonId : 1315956
Emilie Kaufmann
In this paper we revisit the fixed-confidence identification of the Pareto optimal set in a multi-objective multi-armed bandit model. As the sample complexity to identify the exact Pareto set can be very large, a relaxation allowing to output some additional near-optimal arms has been studied. In this work we also tackle alternative relaxations that allow instead to identify a relevant subset of the Pareto set. Notably, we propose a single sampling strategy, called Adaptive Pareto Exploration, that can be used in conjunction with different stopping rules to take into account different relaxations of the Pareto Set Identification problem. We analyze the sample complexity of these different combinations, quantifying in particular the reduction in sample complexity that occurs when one seeks to identify at most k Pareto optimal arms. We showcase the good practical performance of Adaptive Pareto Exploration on a real-world scenario, in which we adaptively explore several vaccination strategies against Covid-19 in order to find the optimal ones when multiple immunogenicity criteria are taken into account.
KKR23.pdf (687.95 Ko) Télécharger le fichier
hal-04306210 , version 1 (24-11-2023)
Paternité
Cyrille Kone, Emilie Kaufmann, Laura Richert. Adaptive Algorithms for Relaxed Pareto Set Identification. NeurIPS 2023 - 37th Conference on Neural Information Processing Systems, Dec 2023, La Nouvelle Orléans, LA, United States. ⟨hal-04306210⟩
48 Consultations
30 Téléchargements
